Brinmar
12/10/2010 11:12
PROBLEMA CON LETTORE PENNA CODICI .. HELP!!!
BUONGIORNO, SONO IN POSSESSO DEL METEREOLOGIC ECLIPSE MS 5145 IN SOSTANZA IL LETTORE FINO A POCO TEMPO FA MI LEGGEVA I CODICI A BARRE STAMPATI SUGLI ARTICOLI DI MAGAZZINO, OGGI MI RITROVO CON LA PENNA FUNZIONANTE E CHE MI LEGGE CORRETTAMENTE I CODICI EN13 PER INTERO DANDOMI ANCHE IL SEGNALE ACUSTICO IL PROBLEMA è CHE ALLA CASSA PASSANDO LA PENNA SUI CODICI NON ME LI RICONOSCE PIù, RIPETO, FINO A POCO FA TUTTO ANDAVA PER IL MEGLIO VORREI SAPERE PASSO PASSO COME RIPROGRAMMARE LA PENNA PER FAR SI CHE LA STESSA LEGGA TUTTI I TIPI DI CODICI A 7, 6, 5 O 4 CIFRE AIUTATEMI.. STO IMPAZZENDO!!!!!!!!!
